Side Mirror / Screen Display
  • Replies 8
Make sure that your left mirror adjustment button is selected and the mirror will automatically fold down when you're reversing.
It's also normal that there would be no reverse camera image when the radio and screen are off.
Hope this helps!
On ‎12‎/‎04‎/‎2018 at 5:28 PM, The Pro said:
Your kind advice, please!
C180 (2012 model), can the left side mirror be pre-set titled on reverse gear? also if the radio not turn on, the screen is blank when reversing is this normal?
1 hour ago, The Pro said:
Many thanks. However how do I pre-set it first as mine is 2012 model no memory button. Cheers!
You're most welcome. To set the mirror dipping:
1. Put your car in reverse.
2. Select the left mirror function.
3. Set the mirror to your desired angle.
When you drive off, the mirror should go back to your driving position and when you put your car into reverse next time, it should resume your set dipped position.
Don't have unless you've the memory package which include
1. front seats
2. wing mirrors
3. Steering column
You are welcome!
In short, if you have memory seats, you will have the reverse tilting mirror!
