Occasional knocking sound when accelerating
Fetch
Hey guys,
I'm driving a 2014 w204 c180. Sometimes my car is having these 2 issues. Help appreciated. Thanks!
1. Especially when driving up slope, sometimes the car will produce this knocking sound (not sure if its from engine or transmission) for a while till gear shift. Only happen once a while.
2. Sharp jerk when gear change from 2 to 1. Especially when you press on the gas hard on initial and release the pedal. The jerk is quite prominent.
Generally speaking...RON 95 is sufficient for Merc cars...incl W204. I don't intend to speak ill of oil companies, but sometimes I have my suspicion that particular day in that particular station somehow the petrol could be tainted with lower RON.....particularly in our neighboring country.
So yes...j88 suggestion of using RON98 is a good idea, even better if you alternate the 95 & 98 or stay 98 all the way.
Thanks jtang. I think I got what you meant. btw, do you have any idea what cause my other issue below?
Are you referring to the down shift gear shock when it kicks down from 2 to 1? Or are you referring to the throttle lift off jerk at low gear?
Btw, has your car been tuned by some piggyback or remapped by a tuner?
