Top up washer Tank fluid
Eld
Hi guys/gals
do you know where to replace the washer wiper fluid tank or pump . I have been topping it up for the pass few days . I suspect is either the tank leaking or the pump leaking . Any workshop that I can go to check it out ?
19 hours ago, Eld said:
Any workshop that can recommend me to go. I have been topping up my wiper washer the past 2 days . Suspect that either is the tank leaking or the pump .
how much will it be to replace it ?
Happen to my old car, the washer tank cracked after hitting something(but you have to diagnose what happen to yours. Do what a fellow former suggest top up and see if the floor beneath has water pooling) I was given 2 choices then, repair S$50.00 or new one $90 if i can rem correctly by the workshop.
my car then left 3 months to scrap so i repaired and it lasted till it was sold to a dealer for scrap.
5 hours ago, darksaint said:
Or can try use a dry cloth and wipe the base or hose to wiper tank see if wet.
Coolant leak easier to see cos got color. 😬
Think is leaking as there is water puddle overnight. Not sure if is the wiper pump or the wiper tank . Don’t think is coolan it is water . Leaking close to the left tire there .
any workshop that can recommend for me to go ?
Hi OP
I send you a PM.
  • 5 months later...
On 24 December 2017 at 4:17 PM, level z said:
Hi OP
I send you a PM.
hi,
able to share which workshop you went to? my car is a w204 and i think the tank is leaking. i was topping it up and noticed that water started leaking out from the bottom of the front bumper
