S300L jerky when tap at pedal
mike9956
Hi Friends, Good Day
When I tap on my pedal around 40-60 kmh while picking up speed, I felt a slight  jerky forward movement of the car. Suppose to be 7G transmission but it wasn't that smooth at low torque due to the momentarily jerk. There is no-error message. 4 months ago, I changed original transmission fluid and new spark plugs. Any advise of the most likely cause ? any short-term cheap solution ?
Looking forward to your advice or comment
Enjoy your weekend...Mike
Not sure about this, probably reset the adaptive transmission control? Else did you check if the correct ATF was used - yours should be the one with the reddish dye, not the yellow one.
