Staggered Tires - Rotation
mysticryan
On ‎9‎/‎26‎/‎2017 at 6:17 PM, VRAtenza said:
if your tires are rotational (have outside/inside surface marking) and directional (have rotation direction arrows), then even side to side also cannot.
if your tires are just rotational, then limited to side to side swap.
Outside marking yes but didn't see the directional marking. Anyway, I will let it be, Hankook tires not as expensive as the rest. Will change when require. Thanks for the info! My only concern now is that my tyres are run flat. not sure if it will be available as and when required.
