GLC SUV Rear Flared Fenders Installation Instructions.
VRAtenza
13 hours ago, Dcky75 said:
Nice! Will that increase the turning radius of the car? I heard the further out the wheel, the bigger the turning radius. Any significant increase in rear road noise?
Not appreciably.
i tried my usual usual U-turns as well as my parent's place MSCP tight up and downslope turns, exactly how I had been driving previously.
The track increase of 25mm each side is chosen because I know for a fact that coupe's staggered 19" AMG rear rims are 9" wide with ET20, based on calculation, I have 25 to 30mm room to push out the wheels if i want to remain within factory specs of the staggered 19" rims.
20/ 21" staggered AMG rims are rolling around with even wider tracks without problem. Especially the rear.
Rear road noise not higher because the tire width remains the same at 235mm and the contact patch is the same.
6 hours ago, Michaeltoh said:
why not push out till 35mm... even nicer right? but will need longer bolts for that....
To be frank....this is the first time I am putting spacers and by myself.
So, being a bit conservative here when I decided on the 25mm. Just want the rear to not look so "tucked-in" ....quite an eyesore between my rear fender flare installation and the spacer installation. If I want even more aggressive,  I would have gone for 20/21" staggered rims for the ultimate aggressive stance
For the H&R spacer system I used, the spacer bolts to the existing wheel hub with it's set of 5 bolts. The rim is then bolted on to the spacer's reinforced bolt holes. No need for extra length bolts.
When I put up the installation pictures it will be clearer.
This H&R spacer system is the preferred one since it is bolted separately to the hub and not using the longer bolts. It makes changing tire easier too. How much it cost you bro?
On 12/08/2017 at 3:21 PM, VRAtenza said:
Choose this option. The option wordings within the bracket means can choose from 2 colours (silver/piano black) and from camera mounting/non-camera mounting.
When checking out, you have to leave message to the seller to specify what combination you want, if not the seller will try to message you with regards to your choice.
The Diamond Grill cost about SGD300??
7 hours ago, Dcky75 said:
Benson I paid $390 with shipping. Got it when Ezybuy has free agent fee and 15% discount on shipping. My grill and 3D logo are bought separately from the same supplier. Cost a bit more. Just the grill is $218. 3D logo is $122. Hope this helps.
Can PM me the link? Thank you very much 😬
  • 3 months later...
