Need Help to Identify Fault (W204)
I found that when my car battery was weak the electronics of the car went wonky. Example: autolight will not be switched on even during heavy rain, car cannot recognise my key for keyless go. All these "faults" went away after I changed my main battery that was 2.5 years old.
On 12/06/2017 at 3:10 PM, Odessus said:
Weak batteries can potentially cause a myriad of errors... Worth checking your battery when too many systems fail at the same time. Rarely do our cars' systems break down all at the same time.
yes check your batt. should be it.
