Screeching brakes on reverse.
SUV-Lover
Dear Fellow Merc owner,
Just want to give an update. It has been 2 weeks since CnC did "something" on the screeching sound on the brakes.
Two week has pass and no more screeching sound.
It seems they may have found the problem and rectify it.
If you having same issue, go CnC and I am sure they will resolve it for you. I believe they have found the solution. Best of all, they did it free.
Cheers.
Cheers.
Hi SUV-Lover,
Thanks for the updates!
Would you be able to advise what exactly is the brake system or shim plate they replace and if they did only on the front or rear?
Thanks,
  • 5 months later...
Cheers.
Hi SUV-Lover,
Can you provide details on what exactly C&C replaced? As with @andylkkg above I have no idea what a shim plate is.
Hi @andylkky and @GLC250 Newbie,
Yes, the brake noise is resolved. Since Aug 2017 when CnC resolved the brake noise issue, it has not re-surface.
If you ask me what CnC done, I really dont know. All they tell me is that a "cover" plate is making some high pitch noise when we press the brake when reversing. They put some shim plate (some kind of a packing plate) to stop this vibration. They told me they did not replace the original brake system.
For full detail, I think you may need to go CnC. I went to Alexandra service centre and all this investigating, fault finding and resolving was handled by Nick. Very nice guy. I am sure he know this issue and will get it done for you.
16 hours ago, GLC250 Newbie said:
Hi SUV-Lover,
A shim plate is the thin metal sheet behind the brake pads, it is usually attached to the brake pads. shown as attached.wheel23_brakepad_12-or.jpg
A cover plate is the metal plate right behind the rotors. Which is between the tie rod and the rotor.
Thanks for the details, hope this time, C n C get it right! Finger cross!
  • 1 year later...
18 hours ago, iconchia said:
Jan 2019 GLC. Having this problem too. PI car.
Just dropped by Optima. Apparently, this problem will be solved if we upgrade to the AMG brake kit. Damage around $1200.
Any bros did that? Thanks
Have the AMG line version (with the AMG brake) and have not encountered any screeching from day one! Fingers crossed!
