Intermittent gear shift issue
Fetch
  • Replies 6
On ‎22‎/‎11‎/‎2016 at 7:45 AM, Fetch said:
My w204 c180 seems having problem shifting gear. rpm hit as high as 6k before gear starts to change and speed cant go beyond 60k. The problem seems intermittent and after restart seems ok. anyone encounter this sympton before?
Go for a diagnostic check to see any faults turn up?
Please see attachment for MY14 Maintenance Manual - a good indication though it's in miles
I used to get the Service Booklet from CnC for all my new rides with them.
Think they have stopped giving out these Service Booklets.
Each time I serviced my car at CnC, they will filled up the Service Booklet and indicated the services they've done and the SA will chopped and signed on the Service booklet
MY14_Maintenance_Booklet.pdf
  • 11 months later...
Brought to C&C and they managed to find the problem and fix it. Apparently was due to the water pump unit that was connected to the vacuum system that causes sudden lost of power. They replaced the water pump and works fine since then. Lucky still under warranty!
