Center headrest and lumber
MasterGMT
My center headrest wouldn't come down when I press the button at center console whereas the other headrest could.
Spoke with the previous owner who is quite knowledgeable, I Finally figured out why both center headrest and lumber support are not working
Many parts are connected: Headrests work on pumps. the center headrest shares the same pump as the lumber support. When the pump for center headrest Fails, or the air-lines to lumber/headrest leaks, or fuse is damaged, both center headrest and lumber will fail simultaneously.
Instead of replacing the pump or checking the fuse or air lines, I simplyremoved the center headrest. Now the rear looks like coupe with 2 headrests. Lol!
