Pocket_Rocket
Sudden Acceleration
Hi all,
I am also experiencing sudden acceleration (2nd time to be exect).... happen when slow speed (less then 30).. anyone also experience this? Very concerning...
Share this post
Link to post
Actually, i noticed that sometimes i get a sudden jerk forwards after i start the car and release handbrake. I guess i'm not stepping the brake hard enough before engaging D?
Share this post
Link to post
Hi Zeenie!
Well mine is already moving already... not from standstill....
Share this post
Link to post
Hi Iks328,
My ride is 2016 FL A250
Oh..New car... How does the acceleration feels... Can elaborate further...? Doesnt sound normal to me....
Share this post
Link to post
After some deep thinking.... i think i MIGHT mistakenly push the cruise control hard which will increase the cruising speed by 10 km/h. I remember that acceleration of that is also quite harsh.
Lets hope its just my human error.....  :phew:
Share this post
Link to post
If your speed is less than 30kph, you can't engage cruise control. Even if cruise control is engaged, the car won't accelerate suddenly.
Share this post
Link to post
Is it a delayed gear change nudge forward?
Hey Odessus,
Thanks for the lead... according to the eplanation below.. it might be and hopefully my reboot of the software will solve it.
Delayed shifting is often caused by valves sticking the valve body, which prevents shifts from happening when they should. On newer cars, which control shifts using a computer, the problem could lie in the shift solenoids that are used to trigger shifts. If this is the case, these components of the transmission will likely need to be serviced or replaced. If the problem lies in the computer itself, then a reconfiguring of the computer is likely all that is necessary. Automatic transmissions also contain spring-loaded dampeners, called accumulators, which ensure that shifts happen gently. If the car suddenly jerks or slams into gear, i.e. the reverse of delayed shifting occurs, then the accumulators are likely to blame.
Thabks Markcwq... yeh i tried yesterday... but in also curious... what if i hold on to my cruise control(increase 10km/h) and softly accelerate... :)
Share this post
Link to post
Silly me... it didnt work....
Share this post
Link to post
hi TS, hows the problem? i think my new merc B180 may also have the same problem
Is it me unlucky? first side mirror tilt problem, now sudden acceleration problem
Is like I am travelling at 10km/h (carpark) then i step on acceleration for a while and feet off.. but when my feet off, there was a sudden uncontrolled acceleration that makes me having to step on the brake.
Can it be due to the part of the road that is slippery? I encountered twice and is over the same patch of the road..
Will be sending my car for to check for  the side mirror tilt problem + now this.,.
Sian
Share this post
Link to post
Sian
Hi Divads,
I brought down my merc to C&C and they could not find anything... they only did a reset on the ECU.
I also did a reset myself:
http://www.mercedesmedic.com/reset-mercedes-benz-transmission-procedure-instructions/
so far so good *fingers cross*
hope this helps...
Share this post
Link to post
Hi Divads,
hope this helps...
wow.. thanks man!!!
My merc is a b180, according to the instructions, some merc the key has to be pulled out while some key remains inside..
(step 4) i referring to after the pressing of the gas pedal for 10s.
Do u take off ur key or remain when u switch to position 0 after the 10s gas pedal?
thanks!
Share this post
Link to post
wow.. thanks man!!!
thanks!
I left the key in
Share this post
Link to post
Like to add that I have this sudden acceleration on my 2016 FL A200. It happened 2 times in the first month that I got my car. Sent the car back to cnc eunos and they did a software update. So far have not encounter the sudden acceleration anymore. It's pretty scary and I have to slam on the brakes hard everytime it happens
Share this post
Link to post
Thank for sharing Routey!
Whats the down time for the software update?
Share this post
Link to post
2 days... left my car in the morning, took back the next day late afternoon
Just went to alexandra. MAnaged to show the service executive the side mirror tilt problem.
As for the sudden acceleration, I told him about advice i got from here aka software update/reset.. he says can be done but needs time
So left my car there. He said tomorrow shd be ready
Fingers crossed.
Will update
Share this post
Link to post
