Check Battery Voltage from Dash c200 W204 2012
Is there anyone know how to check battery voltage from dash using steering buttons?
I'm using c200 W204 2012 and previously saw that Merc engineer doing this easily so we can know the voltage of the vehicle battery.
Thank you in advance
If you have control from the steering wheel , see if it works:
1. Put your display to outside temp.
2. Key to position 1
3. Press reset button (left on the cluster) 3 times
4. Temp display will change to voltage of your main battery
Or simply google using key words like model no and voltage display
https://www.youtube.com/watch?v=YZtXG7IOdlk
But i try like cannot leh. Haha. Maybe somewhere i did wrong?
Try....need to press & hold the phone answer and the ok button together for 3 secs.
Bro sure can. I did many times before.
it doesn't work as there's no reset button on my c200 w204 :(
anyway i have try other advise as using: Key in ignition, select default menu (odometer) --> hold 'OK' and 'pick up phone' buttons for a few seconds (on the steering wheel) and it works :)
Thanks for the info :)
  • 3 years later...
