Sanity Check
mike9956
Hi Bro, Good Day
I got a quote from a popular workshop in Sin Ming to replace a pair each of front airmatic suspension (OEM BIlstein), lower control arm (Euro OEM Meyle/Mahle) and front linkage (Euro OEM Meyle/Mahle).  Labour/supply  $4818 (incl GST).  This is the 1st change in 97,000km. Am I overpaying ? Know of a  cheaper solution ?
Would like to hear from you !!
Cheers...Mike
  • Replies 7
Last I done the replacement my cost as follows:
Front air Matic around 950 one piece
Lower arm 150 one piece
Thrust arm 130 one piece
Total including labour should cost you less than 3000 to replace
I did mine at Chip Soon.
Blistern front right airmatic, radiator return valve, rubber hoses, transmission oil change, service (lube) change. total damage 1800$.
brake disk & pad, lower front arm not changed.
of course it's better to change a pair so as to strike a "balance", usually if you change just 1-side and go for wheel alignment (important), it should ride ok. However, since the other side of the airmatic strut is also "old" liao, it is only a matter of time you will need to replace it (usually within next 1 year). It's air suspension, ride is acceptably ok.
it's up to you and your expectation of a smooth ride. :phew:
