Enabling Lines for the Reverse Camera on W204
jskywalker
After lamenting for 2 yrs why aren't there guiding lines on the reverse camera for my W204, I finally found how to enable it....I would like to know what else can I do in the Reverse Camera configuration menu? Also how do you use the lines, the furthest is blue, then yellow and red.
  • Replies 3
As the camera is not centred to the car, you need to get the lines calibrated if not it's as good as useless. Don't mess around with the menu, there are also cases I know of where the system "bricked" because of false inputs.
If you want to calibrate the lines, I suggest you get a professional to do it. EleBest for example.
Hi Jskywalker. Can you let us know the steps to enable the guiding lines?
Thanks in advance.
