W204 cannot detect IPhone 6s Bluetooth
Just changed my phone from iPhone 4s to iPhone 6s. Before changed the Bluetooth was all ok, able to pair and no issue with connectivity. Now after changed, tried to search my iPhone 6 Bluetooth but dash error message says cannot find.
Anyone have this issue of searching and pairing any iphone? Any recommended solution?
  • Replies 10
I have Comand Online and am able to connect my iPhone 6S via bluetooth. I'm assuming that Audio 20 should also support the same model of phones. It'll take me usually 2 to 3 rounds of searching for my iPhone before the car will find it. You might want to give it another try? By the way, mine is a FL model.
I am thinking of getting iPhone 6S Plus. Did you restore from backup? Try deleting all existing connections in both car and phone, and try pairing again?
I always restore my new iPhone with backups of my old one. However, the bluetooth profile will always change with each individual device. You will need to pair the connection again.
Thanks for all the input guys. Mine is FL too. Deleted all the existing paired devices, reset all settings in car and also in iPhone 6s. Tried again and again many times to search for my iphone Bluetooth.. But sigh every time tells me cannot find.
Maybe the new ios9 on the iPhone not compatible.
Test another Bluetooth phone or 6s to your car to check if due to car Bluetooth?
You may try call Elebest to check if they have any solution on this as well.
