W204 Coupe Electronic Seat Out of Position
Ah Neo
I have this issue where the Coupe's Passenger seat gets out of position after a while (maybe 3-6 mths) of usage.
Out of position means the the electronic adjuster is at the max position but the seat is still very low in inclination, seems like the gear mechanism keeps "jumping teeth" whenever you fold the frontseat to get people out from the rear.
I know I can get it fixed at C&C but just to find out if this is a simple procedure to reset the electronic alignment position yourself.
Thanks.
Is not easy to get C&C to change the ECU and they will BS you around and tell you grandfather stories.
It took me 3 rounds to get them to change the ECU
1st time they check and found no problems and told me to monitor.
2nd I went back and they BS me again so I make the SE to write down black and white on the paper if the Seat fails again C&C must change the ECU
3rd time I went back and C&C Check the car and BS me again. The same SE told me to monitor again
But this time I show the SE the previous service report remark written by him and the video taken when the seats are not working. The SE quickly take back his words and offer to change the ECU
Since the ECU changed, the seats work fine till today.
I think only in Singapore, MB brand is given such poor follow up service by C&C.
C&C is telling current customers and potential customers to look for other car brands if they want good follow up services
Victoria Concordia Crescit
