A180 style fall in
iceman313
Hi, anyone knows if the FL A180 has CarPlay as standard? Or is it an COMAND option? Thanks!
Negative, no CarPlay as standard, remains in COMMAND option which is approx S$10-12k more (totally not worth it imo).
Quote/Unquote
1) Mercedes-Benz has issued an internal announcement to U.S. dealers (via C450 AMG) that confirms CarPlay will be supported in a number of 2016 model year vehicles starting with December 1, 2015 or January 8, 2016 production or later.
2) CarPlay will be available in select CLA, CLS, GLA, GLE, E-Class, and B-Class models produced after December 1, 2015.
Cents
Quote/Unquote
Cents
Ahh I see, quite a disappointment zzz. Thanks for the heads up!
I had been advise from Se my next servicing is 15000. Or 1 yrs. Will all of your follow?
What is more important is the rationale for this longer service interval. It does not mean any car you can do so or even Mercedes you can do so (if different engine oil is use).
Too long to type. If interested to know, I am happy to have a chat over cup of nice coffee.
Hi. Need some help please. I noticed the car roll back on slop a bit. I read the instruction manual that the car has a brake hold function but I can't seems to activate it. Does anyone know if our a class had this feature and how to activate it ?
Secondly when I am on auto start stop at traffic light and the engine cuts off..very often my aircon turns the closed circulation off and I have to turn it on again very frequently . Anyone knows how to prevent that without deactivating the start stop ?
Thanks in advance
Still trying to figure out the car
Thanks in advance
Hi there,
To activate brake hold simply depress brake gently all the way down. You should see a (HOLD) in between your temp and time display at the top. Anyway, my car doesn't roll back even on steep slopes without the brake hold function. Maybe U might wanna check with your SE?
And I don't think U can change AC settings without deactivating auto start stop
Haha my two cents hope this helps
