views on 20inch for e250 coupe
kannan
Here's are my thoughts on 20" rims.  Had them for 3 years now.  I'm driving a E350 cabriolet.  I've never driven it with any other wheels do i don't know if there is a power loss.  I wouldn't expect you to lose much HPs if you keep the weight the same as your 19".
PROS:
- Looks great!
CONS:
- expensive tyres.  PSS are SGD500+ each.
- tyres leaks from the sides if you kerb your wheels.  You're running on very low profile tyres and once you kerb them, the tyres will peel from the rims and debris will get in between.  You'd get slow leaks after that.
- bumpy ride.  Bumpy even if you're not lowered.  I'm on stock suspensions.
Don't get 3 piece wheels, they leak between the gaps / joints and you'd end up having to pump air every 2 weeks.
Hope this helps.
