reverse side mirror auto tilt
Hi
Can anyone help me? recently I just got my E class. having been driving for 2mth and I am faced with this problem which irritates me quite a bit. Whenever I put to auto tilt for the side mirror, it sometimes does not return to the original position when done with reversing, like a back lash. but sometime it does and this really piss me off so I disable it since it sometime will and sometime will not. anyone face this problem before?
Please help
Thanks.
  • Replies 9
Did u brought it from a dealer? If yes, get them to resolve the mirror issue for u. How u disable the mirror? If u select the switch to driver side it wont tilt down. But u mention sometimes it does? Else try this, put to reverse then tilt the mirror to the angle of your perference. Then monitor again. Hopes this helps.
Last time my w203 also have this issue. Could be motor failing due to wear and tear if setting is correct.
Woah... motor failing! The mirror doesn't return to its initial setting immediately after you stop reversing and put to park. So if you turn off your engine wait awhile in position 1 for it to tilt back before u turn off and pull out your key. If you are using Keyless entry / ignition this process should be automatic. Otherwise maybe really motor failing :startle:
  • 10 months later...
my new b180 also facing same problem abeit different problem. The side mirror does tilt back but it does not return to the EXACT original position. It misses by around 1-2 cm and i have press the Memory button 1 to return the side mirror to the exact position.
Is this problem common? cant be the motor failing becos is a new car..
Hi
Please help
Thanks.
ya u have the exact same problem but when I visit the workshop it never happen .. so in the end I gave up I disable the function and anyway I don't like the auto tilt too. my wife collecting her a180 style soon will check if it has the same problem too.
So far no such issue with W205. The side mirror will tilt back to the original position when the R gear is disengaged.
hi.. tilt back to the EXACT original position??
Does it miss by abit say a few mm? How to know? when u press memory button 1, the mirror will adjust abit back to the EXACT original position..
So everytime it goes back to the EXACT original position?
Thanks
Thanks
To me, it does tilt back to the original position. Also, I do not have any memory button to press. When I engaged the D or N gear, it will auto tilt back.
how u disable the auto tilt bro
