Cahn77
installing pulley on m271 engine
35 posts in this topic
Recently got to know Benzline carries crank pulley from Euro motorsports when installing piggy ECU. Damn itchy to try out. Downtime only 45mins. Heard they installed many. Any brudder here have this installed by them?
Share this post
Link to post
Hi Sleath arrow, where u got ur pulley.I only know benz line sell it
Share this post
Link to post
PMed.
Crank pulley free up rotational restriction due to light weight so engine revs easier and builds energy faster and better gas mileage.
The rule of thumb is that each pound of weight taken off the engines rotating assembly is worth approximately 2.7HP. The concept is that the crank is a parasite; it does not put power to the drivetrain but still requires the energy produced by the engine to rotate. When you reduce this parasitic weight, you release power that was previously used only for spinning the supercharger.
Since the crank pulley diameter is unchanged, they maintain exactly stock output levels so you need not worry about flat batteries or weak charging capabilities. Through extensive weight savings afforded by aluminum construction, power gains of up to 10% are expected.
To really reduce rotational mass and improve acceleration, use a lightweight supercharger pulley along with a lightened crank pulley (same diameter as stock crank pulley).
1 person likes this
Share this post
Link to post
Its not Euro Motorsports.
It is Exclusive Motorsports..or EM (in short)
http://em-tuning.com/lightweightpulley.html
Share this post
Link to post
On 11/7/2014 at 11:27 AM, Stealth Arrow said:
PMed.
Hi stealth.. can i know where u have installed the light weight crank pulley.
Thanks
Teckteck
Share this post
Link to post
2014 thread. 4 years liao !
Share this post
Link to post
Interested too
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
