Power windows not working using remote
jas126
Previously i was able to put down all windows using the remote while i approach my car, useful especially when parked under hot sun for a while.
Today when i wanted to repeat same feat, found that i wasn't able to?? No matter how long I've pressed the unlock button on my remote, the windows just doesnt move a single bit...
What could be wrong? Any advice?
Thanks!
  • Replies 14
See the black thing i pointed out on the Picture? That is the sensor unit which you suppose to point your key at.
damn... I always point at my nose..... No wonder they don't work......
why point at your nose should point at some chio bu sure can work one
Provided it's aimed using a gun.... Best if use a rifle
you go n try leh...
point at your head, nose etc...then share which body part works best as an antenna...
i only know that pointing at ur head increases range...
Actually if never use remote
If ur car handle driver side got lock and unlock sensor using hand..
U can
Touch 2 x lock
Pull handle it will open all window
Close all window also same
That's provided if the car comes with keyless entry. Most W204 don't come with it.
Cannot... Ur case slightly serious... Must stuck it into ur nose. Probably it will work... Lol
You guys are hilarious!!! LOL
Yes bro you are right, mine doesn't come with keyless entry.
Other method is open door , plug in the key, turn to battery mode and press all window down
