Car DVR w power saver
darksaint
If you fart in the car you may void warranty for the air con as well. Don't be scared. I installed and even after 3 servicing and one warranty claim no one said a thing.
Lucky your roof can open! Lol
Ya, installing a DVR with a power saver would probably be one of the most minute mod (if it is considered a mod). Compared to exhaust, engine tuning, changing of springs, etc.
  • 4 months later...
So far ok. :)
2nd day onwards the device no power light indication. They say maybe merc car sensitive can't use w power saver. When on the way back on expressway. Car suddenly lose power. Only 60km/h speed. Went back workshop and they redo wiring. So far ok...
Bro, what did you do? Remove power saver and continue using itb-100hd, and solve your car problem?
  • 4 months later...
Yup. No power saver and direct connect to DVR. :)
hi darksaint,
so does that mean it doesn't record when you are parked and the engine is off?
and what power saver device/module did u use that time?
i know someone already asked, but how is ur dvr so far (up till now)?
hi darksaint,
it will still record when in park mode. just that it will keep draining the battery.
not sure wat was the power saver brand.
so far no other issue. :)
