Noobest question about brake/tail light
green_carnation
Hi guys.. Got a noob question.. Need advice. Today my w204 meter cluster showed that left brake/tail light message. Being a bit slow I only realised it could be brake/tail light blown. Indeed it is. So my question is.. Where can I go get it fixed, besides c&c? Sorry for such a question..
  • Replies 18
Check yr manual how to replace the bulb is a child play.
Most workshop could help you replace your bulb. example Autobac and such they sell bulbs
Thanks for the fast response.. Off to dig out my manual :)
Let me know if u needs help. Most workshop can help u to replace the bulb, if harness then is difference story.
1 pair would cost around $5-$100 depends on brand and also the power
Send to the workshop they would be able to replace for you.
btw if you have the 2 or more bulbs errors at the same time there might be a possibility of burned wire
Burned wire.. That sounds very bad.. Shouldn't be that I suppose..
Need to see what bulb is it for the brake tail lamp.. Shouldn't be too ex..
Mine at the 6th month mark threw out lots of bulb errors, calling out the rear lights eg. tail, brake and side. All were working, but the signal left/right blinked faster than usual, suspected that the computer wrongly detected no bulb installed. The errors miraculously disappeared after I parked for a while.
At the boot, on the side there is a compartment. Open it up and reseat all the connections. You may see some frayed bits, I think it is a known issue for the harness.
