Engine oil
For your car (06) model....I believe 5w-40 fully synthetic oil is good as it gives better mileage. But pls change the oil every 10k km religiously as older engines do leave more deposits in the oil. Don't try 0w-30 on your car...unless you want a major engine overhaul job prematurely.
Mobile gold 5w-40. Good for my C180 coupe. Am so pleased back den.
Y I so kaypoh. Cos I sayang cars.
Thank you all bros, for your inputs.... Think I should try to use 5w-40 the next round and c c... :) yeah i also think abt time ti change engine oil i m at 6kplus liao. Bro TaZen, not Kpo la....all opinions are all very valuable.  :D
 btw, is this the one we are looking at? ----> http://www.amazon.com/Mobil-105856-CASE-5W-40-Formula-Motor/dp/B009IE2N4A/ref=br_lf_m_1000922221_1_16_ttl?ie=UTF8&m=ATVPDKIKX0DER&s=automotive&pf_rd_p=1548826182&pf_rd_s=center-3&pf_rd_t=1401&pf_rd_i=1000922221&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1PPJ9VAP7TVJVZ4NRKS4
wow Dont even know they have a testing for the oils for our cars......but then again....my car still running well and not exploded yet so i think its ok.
Used to be using the amsoil for my previous car and intended to do the same for my current w204 until I saw the list.. Didn't wanna take risk so I went Mobil.
I still have a quart amsoil 5w40 euro formula in my store room. ..pm me if u want.
give Ah Bui me...
Drink already engine work well.... Now very cranky..... Every morning wake up cold start.. Here pain there pain.... Hiaz...
Don't worry, Amsoil produces premium oil, as long as u stick to the recommended viscosity grade, u are fine. I have tried many ranging from Redline, Amsoil, Castrol and Roar. Redline polyol ester base has tremendous stability and low volatility. Castro edge has strong oxidation control and longer wear protection. Amsoil is race proven. If one is worried, then they can stick with normal engine oil like Mobil, Shell or SPC.
Mobil 1 (Gold) is still the best. How old is your ride? If its more than 2 yrs, 5w30 Grade is not recommended. Incidentally, the CGI engines are really hot due to the Turbo. Though C&C recommends 15k km service interval, I would prefer to do an oil change (only) in between at 7-8k km.
Hi
Is Mobil 1 Gold is 5w40?
