Fine tuning by Monster Tune
jes
A brand new development:
Mercedes C200 W205 Monster Tuned:
At the wheels:
Base: 166WHP & 278NM
Monster Tune: 204WHP & 336NM (38WHP & 58NM gains at the wheels)
At the crank (est.):
Base: 221HP & 369NM
Monster Tune: 272HP & 446NM (51HP & 77NM gains at the crank est.)
Tuning for ron95 is definitely possible. However, most who tuned to Ron98 do see better mileage running on ron98 as compared to their previous choice of running on ron95 (when car was stock). Some customers have given us feedback that the mileage gained worked out to be more economical as compared to what they used to pay when running on ron95. However, please note that this isn't something we guarantee but rather, it's based on actual feedback by most customers.
Hi guys
after tuning, do you guys use petrol 98 or can continue to use petrol 95 ?  Any knocking if on petrol 95 ?
Asking because 98 is so expensive nowadays.
Thanks
Have a burning question, perhaps our expert here could advise on piggy back.
Since there is no alternation to the ECU, will the gains from the piggy back be temporary?
Perhaps good for 10K to 20K Km, then the ECU will learn that the signal is false and will revert back to stock.
Many thanks
Many thanks
No. That will not happen as the piggyback works on the principle of altering the incoming signals (in voltage)into the ECU to fool it of lower value such that the output signal from ECU to engine will be stronger dose of boost, fuel and ignition timing to create higher horse power and torque. However, this method has limited effect due to the range of incoming fixed signal alteration and no alteration to fuel and ignition maps of ECU as a whole.
Thanks for the reply.
I always have this worry that the ECU would "adapt" to whatever signal that is coming in and it would render the piggyback useless, unless there is a feedback loop in the piggy back that "sense" if the ECU is adapting and would alter the parameters accordingly.
