Servicing Mercedes
Just did my 130k serving today.
Cost me $1,088 using Mobil Gold for engine oil....Met a fellow S class owner at workshop who is doing his servicing and he said the Mobil Gold will make ur ride feel very smooth but at a premium price $200 for 8L did went for a quick run from workshop to home and yes it feel dam shoick with this Oil
http://www.mobil1.com.sg/products/product_0W40.aspx
Well this is what I did
2x Rear disc rotor
2x rear brake pad
2x rear brake pad cable
engine oil
air filter
fuel filter
air con gas top up
oil filter
tyre rotation
tyre wheel balancing
  • Like 2
hahah i thought u just go service ur ride?
Wah. You make me wanna go for another servicing even though my B doesn't need one.
They did the basic....engine oil , air filter.
The rest is what I told them I wanted to be change
They also recommend me what is needed to be changed as well
This workshop knows they cant change things for me based on mileage as my car I did a lot of impromptu change eg 123k i did ATF,
116k i did change of brake
115k i did Airmatic replacement
Do you tell the workshop what you want to do or workshop recommend what to do based on mileage?
2x Rear disc rotor
2x rear brake pad
engine oil
air filter
fuel filter
air con gas top up
oil filter
tyre rotation
Bro can share the name of The workshop? My 60k servicing is due soon not going back c&c.
Round Motor Repairs & Services
Address : 10 Ang Mo Kio Industrial Park 2A #01-19 AMK Autopoint S(568047)
Phone : 64812777
Fax : 64812555
Operating hours:9am-6pm(mon-sat)
No appointment needed
First come first serve
I must admit. You got a good price for this job. I realize it's cheaper as compared to my $900 brake changes and your total is just over one K.
2x Rear disc rotor
2x rear brake pad
engine oil
air filter
fuel filter
air con gas top up
oil filter
tyre rotation
2008 W245 Black with no mods yet.
B 170 in the East
Mine is the older s class W220
Guys wanna hear some opinion... my 45k mark is up and thinking to skip c&c and just go for outside workshop if cost is high. Can anyone share rough cost if service at c&c?
I did my brake pads outside and is comfortable with outside service standard so if c&c charges too much then no point going back to them.
Thanks.
It depends on what is needed to be changed.
A SERVICE :
- Inspect and record tread depth, and correct tire pressure
- Rotate tires (excludes AMG, Sports Models, SLK, and vehicles with staggered wheels)
- Engine oil change and oil filter replacement
-Includes Mobil 1 synthetic oil
- Lubrication service
- Includes hood hinges, lock cylinders, striker
plates, sun roof tracks and top off all fluids
- Cooling system inspection
- Includes antifreeze protection level, hoses and
clamps
- Brake inspection
- Includes check of pad thickness and condition of
discs, fluids and lines
- Inspect heating and ventilation dust filter, replace if needed. (Replacement additional. Dust filter prices vary by model)
- Function check
- Includes warning lamps, headlights, exterior
lights, seat belts, windshield wiper and washer
- Inspect and lubricate throttle linkage
- Check and clean air filter
- Reset flexible service system counter
B SERVICE :
- Inspect windshield wiper inserts and service windshield washer system (Replacement of wiper inserts additional*).
- Inspect and rotate tires, record tread depth, and correct tire pressure. (Wheel balance additional*).
-excludes AMG, Sports Models, SLK, and vehicles
clamps
- Brake inspection
- Inspect heating and ventilation dust filter, replace if needed. (Replacement additional*. Dust filter prices vary by model)
- Function check
- Inspect front axle ball joints; check steering play and power steering clutch; and rear differential levels
- Inspect Poly V-Belt for condition
- Inspect starting and charging system and service battery
- Inspect climate control refrigerant
Thanks.
Can u share what is your ride?
mine is w204... it should be just Service A but i dont need air filter (DIY'd), brake pads (replaced outside), so should be just the standard checks plus EO and EO filter. On staggered set up so no need to rotate.
Brake disc i would also change outside but probably can wait till 60K. :)
thanks for advising! :thumbsu:
they will still change air filter for u......
w204 i cant advice if i am not wrong should be below $400
Bro this is general chat .... No difference in classes.....
