SkyHawk
Servicing Issue: Service D at 100,000 KM
11 posts in this topic
HI
I'm new here.
I took over a pre-owned MB E200K YOM 2008, the cluster show service D in 1000 KM.
What is service D, I called up CnC and they told me is a major service that will cost min 1.2K?
Can anyone advice whether I should bring the car back to CnC or I should go somewhere else?
Thks in adv.
Share this post
Link to post
I just did mine change engine oil, filter, transmission oil, sparks, rotate tires. Bought most of the stuff from Sin Ming area and Gallop. I drove around my place and found a workshop that is free n got it done within 2 hrs.
1 person likes this
Share this post
Link to post
Thanks, are they also reset the instrument cluster?
Share this post
Link to post
They only do the servicing. I heard from a friend that there are ways resetting it but yet to try. There are also all kind of 3rd party scanners available in the market that could do the job.
Share this post
Link to post
How do you know what type/model for the spares that will fit your car when you buy from Sin MIng? Part numbers needed?
Share this post
Link to post
Bro it's quite easy. All the Parts seller are expert. You just need to give them your car number or chassis number. Gallop deal with MB parts, you just need to call them to check for stocks. I get most of my parts from the auto parts supplier located beside sin ming famous roti prata coffee shop. Anyway if you happen to buy the wrong parts or extra parts you can just return back to the supplier and get a refund. When I did my CVT oil change, i didn't know how much oil is needed and supplier allow me to bring 7 ltr to the workshop and return all un-used oil later.
Share this post
Link to post
Sin Ming famous roti prate shop???? You mean Prata shop is along Thomson Road and the spare part shop is behind the prata shop... below HDB row of shop?
Share this post
Link to post
I just learn how to reset the cluster today.
1) set the display to show the mileage
2) turn off your engine
3) insert the key n turn just 1 click
4) press the reset button 3 times and the display will show Battery Voltage
5) use the selection button (steering wheel) to toggle to Services
If you select Full Services the system will reset to 15,000km.
3 people like this
Share this post
Link to post
To reset cluster for C class w204.
Insert the key and turn 1 click. Press the phone button and hold it, press the OK button for 3 sec.
Same procedure for E class. Just try it with my neighbors.
Share this post
Link to post
Bro Angchug,
Care to share the workshop and the price for the workmanship. Many thanks in advance.
Share this post
Link to post
You can do a normal services and reset the cluster as Full Services.
I usually services my ride around Sin Ming area. Most of the workshop can help your to reset with Chinese diagnostic kit.
1 person likes this
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
