WTS: FL W204 rear lamp. Good condition
Deko
  • Replies 11
C180/200/250/300 should use this tail lamp too but FL ones
Which car this tail lamps came off from?
this is the prefacelift rear lights
As you can see from the above pic
Malaysia's CKD pre fl W204 c class are equipped with it
is the same as W212 in singapore
Elegance spec: halogen indicator
Advantgarde spec: dual stril LED indicator
So which car can this pair fit then? Thanks bro
For the info
Pre Facelift but you probably need a module to run the LED dual strip indicator
I ve converted my W212 from halogen to Dual strip Led indicator with Ah Boon,
Down time about 1 hr and I think the cost is 100 over dollars
