w204 engine start up
fiqueudrue
Hello guys. Am a proud owner of c200k now.
However, is it normal for the engine start up to be noisy? when it was warm, i off and restart the engine, no noise...
sorry if i have ask this question and its being answered before, but well heck im new here and ive been searching for this topic in this thread to no avail.
thanks guys in advance!
  • Replies 19
Sound like mine, do u turn on your aircon when in cold start?
Any bro has the same prob as mine, engine start after 2-3 sec of cranking. When start, sounds like taxi:( I'm driving a C180CGI.
I found the cold start of aircon esp in auto mode is usually very noisy. We are using everything the same except the gearbox and also supercharger/turbocharger if i am not wrong.
But if we cold start in aircon off mode is not that noisy
Next time if vey noisy off the aircon and See if the noise reduced
guess i need to monitor this noise. maybe the car have not start for a couple of days hence the noise required for the supercharged engine to get all those oil in place. just my guess HAHA!!
Highly possible....if the ride is not started for 12hrs or more or the night weather is "cold"....
Alright guys, noise is gone. Might be too long never on.
However, is the steering wheel by default steer to the left? I read abt some bolt or joint regarding LHD convert to RHD etc2.. Do normal alignment should able to fix this?
And when reverse, it is normal when fully turn, car will have no power or need to depress more gas?
Hi Guys,
Can i check with you some issues from my W204?
I have a delay starting. After turning my key all the way to the right ignition, engine only start cranking 2-3secs later.. It cranks really fast, so battery should be ok.
Any idea how to resolve the delay?
Hi Guys,
if confirm battery still good, sounds like the car cant get enough fuel to start, maybe check the fuel pressure or something, something to do with the fuel line or filter or pump.  can also be crank sensor.. but...
not quite sure though but i think somewhere along there...  :D
